Coolant tempepature gauge question
Mr. Y
80 miles away from Kremlin
Hello. My stock coolant gauge (on '87T) doesn't working (it always shows very cold temp), so I have 2 questions:
1). Where is located sender for this gauge? (I saw picture with sensors here, but cant find it now)
2). Have you any ideas, what causes that trouble?
Thank you :)
Could be anything broken wire faulty gauge faulty sender.
Mr. Y
Thank you.
Another question: can I check wiring by grounding wire, that goes on sender? I suppose, that if wiring is good, gauge on the dash should show overheat, when grounding wire - am I right?
