Coolant overflow relocation
Sawbladz
1,727
Oshawa, ON, CA
So I am standing in front of my car, ovreflow in hand and I notice that there is no room for it anymore due to my FMIC.
So I pose the question, what did everybody else do? My options are to relocate the stock tank or buy a smaller/better shaped aftermarket and mount it somewhere. Just trying to get some ideas.
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
there was another member here who relocated his battery to the trunk and put the coolant overflow where the battery was.
dont remember who or where or when LOL
just remember seeing it
Sawbladz
1,727
Oshawa, ON, CA
Poodles;1529544 said:
Custom will work fine as long as it has a syphon tube and stores enough.
Most of the custom ones I have seen have just a rad cap on top and a single port at the bottom. Will that work? Will the bird cage light be on? Not entirely sure how that sensor works. Which ones are you talking about that need to be shortened?
The spot I think I would like to move it to is next to my air filter.
---------- Post added at 12:32 AM ---------- Previous post was at 12:28 AM ----------
hvyman;1529543 said:
You need the same size tank.
Have you tried slightly moving it upwards?
To be honest I haven't even found the bracket forit yet to try and do anything. I just don't like how cluttered its getting between my IC and rad. I already have my power steering reservoir and oil cooler in there. Don't want the coolant overflow hindering the air flow.
Birdcage light faults open (meaning if you disconnected the sensor it won't come on), but you'll lose it's function. Most don't have a release or a syphon tube though...
Sawbladz
1,727
Oshawa, ON, CA
I would like to retain its function. Looks like I might be relocating the stock unit. It will look like hell but I know it will retain the stock function. Maybe I will get a new one so its clean.
Sawbladz
1,727
Oshawa, ON, CA
I likely could but the more I look at aftermarket reservoirs, the less I want to spend $100+. Moving the stock unit will get the car driveable and in the summer when I have income again I will order something pretty.
Kevin
Apr 20, 2009
865
keep the stock unit and cover it with something pretty LOL (i wouldnt do this myself...) just throwing out an idea..
maybe paint it or something (leaving the min and max marks still visible ofcourse)
wrap it in some aluminum foil?? haha
I have heard of it going just slightly above stock and working fine with aftermarket intercoolers. Iirc all the did was bend one tab and move it upwards one hole.
T701jz
3M ENGINEER - R.&.D
Jul 23, 2005
657
Santa Clarita Ca.
www.optionimports.com
Aluminum reservoir
Kckazdude
1,239
Memphis, TN
Adjuster has the cleanest factory relocation I have seen. Dont have any details of it other than this picture posted in his F/S ad.
Sawbladz
1,727
Oshawa, ON, CA
That would be a great solution if I was relocating my battery but there are way too many drawbacks to having the battery in the trunk.
