Coolant leak from drain plug?
radiod
1,342
Abbotsford, BC
I'm 99% sure that's where it's coming from, just a couple tiny drops landing almost directly under the tube from the rad drain. Is this common? Should I just drain, put some sort of sealer on the threads of the plug, and put it all back together or get a replacement plug?
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
Depends on the plug. Some have an O ring while some have tapered sealing surfaces that can be polished out. No way to know without having a look. Assuming it's really the plug and not the rad itself it should be easy to fix though...
radiod
1,342
Abbotsford, BC
Reason I'm assuming the plug at this point is because it is wet at the bottom of the drain tube but I haven't noticed any wetness on the outside of it. It's a stock toyota rad, so if I were to be a guessing person the plug would be the same as well. I guess I'll start with just trying to reseal the plug, whether that be an O-ring or using some sealant of some sorts and see where it goes from there.
What would you recommend using on the threads? First thoughts I had was just some teflon tape, but would that get all messed up with the heat?
Oct 11, 2005
3,822
27
Thousand Oaks, CA
If its a stock Toyota rad then it will be an o-ring seal. I've seen the plug itself crack since it is made of plastic. Best bet is to pull it out and inspect. O-ring and plug are a cheap fix.
radiod
1,342
Abbotsford, BC
If the plug itself is cheap I may as well just get a new one. No harm in even having a spare if the one I have just needs an O-ring.
iwannadie
981
gilbert, az
radiod;1589907 said:
Who needed that drain plug anyway? Just pop off the lower hose if you want to drain, right?
I use the drain plug, drops the coolant right into a bucket and doesn't spill a drop doing it that way.
