C-flo;1401475 said:
So is there a way to keep from spilling power steering fluid all over the place once you remove the bottom hose, or it is what it is? And the screen your talking about, it is affiliated with the power steering resevoir, and is there a special way to flush it?
don't remove the p/s tank, just move it outta the way, much cleaner that way, if you spill any pour petrol on it asap! (petrol mixes with the oil and it will wipe right up stain free on concrete)
you can remove the hose on car (i've done it!)
use needle nose plyers on the spring clips. i hate spring clips, i copped a large one to the eye about 6 months ago ended up in hospital with internal bleeding in my eye, ended up ok. but keep that in mind
the little pricks can just jump off plyer's...
