Confused :( Please help.
Atsushi7mgte
203
Oahu, Hawaii
Ok so when ever i start up my car it doesnt like just roar to life like it used to, it sorta just fires and then slowly builds revs till idle (unless i throttle it) but then the idle and oil pressure are freaking high (1500rpm and about 60psi). But as it starts to warm up the idle slowly drops but it like stutters a little between shifts during "spirited driving"
the only thing ive done to the car recently besides my drop springs is i removed the cruise control. Can the cruise control being unplugged somehow be the culprit?
giterboosted
cure for the common rice
Nov 3, 2007
597
toccoa ga
You probably have a huge vaccume leak my friend, there's a vac line that helps the cruise function, cap it or reroute it, can't remember where it comes from so hull hafta look to see the proper course of action
