compression test results question?
RPSil13
464
Anaheim, CA
didnt want to start a whole new thread but it didnt let me post on an old thread b/c it was too old, my questions is... will not disconnecting the cam sensor cause you to get wrong/bad readings
i got
1. 165
2. 160
3. 162
4. 165
5. 160
6. 162
are these numbers a bit high, seems like everyone else is getting around 150,
FloTex
Crankin since the 1900s
Aug 13, 2008
47
Tallahassee, Florida
Results look good. Not disconnecting the CPS should not mess the readings up.
There is a procedure documented in the "Articles" tab on the menu bar.
They look perfect to me. The last time I did mine, I got roughly 165-170. I did it on a warm engine with the throttle opened up 100%.
Bri7man
"Yeah! Take the lemons.."
Jul 17, 2009
580
Torrance, CA
Normal operating temp with throttle wide open and a fully charged battery.
I had mine being powered by a idling car for most accurate results.
Drake69
Enjoyin' mah ride...
Aug 24, 2009
648
Richmond, Virginia, United States
suprahero;1457648 said:
Found this in our Articles section. For those of you who haven't checked it out, it's got some really cool and informative threads on there. Top left of this page.
http://www.supramania.com/forums/showthread.php?t=97725
Ohhh yeah. I printed that off a week ago when I had bought my sparks and wires. That makes the whole process easy as can be. It's also important to note that you will also need the procedures to remove the 3000 pipe and coilpack, and it doesn't hurt to swap out your plugs and wires if you haven't already done so. I printed everything off in order so there would be no question what needed to come off first, what needed to be done next, etc...
EDIT: the other procedures are also located in the Articles section as well. They are...
http://www.supramania.com/forums/showthread.php?t=97683&highlight=removing+3000 ---> 3000 pipe
http://www.supramania.com/forums/showthread.php?t=97684&highlight=removing+3000 ---> coil pack
RPSil13
464
Anaheim, CA
I did my test cold b/c I had it apart to change plugs and vc gasket
and no throttle, in the tsrm it doesn't say anything about wot, unless I misread
suprarich
Guest
Nov 9, 2005
2,187
ohio
You should also pull the efi fuse. spraying fuel into your cylinder durning the test will give you a false higher number since fuel takes up space.
RPSil13
464
Anaheim, CA
yup this was w/ the efi fuse pulled.
thanks everyone for the input, i guess, my engine has pretty good compression
