Compatable Injectors?
blk92suprat
J Zizzle
Jul 6, 2008
456
USA
Hey everyone
I found a set of Lucas 550's w/ clips for the Stealth/3000GT for only $300 new. This is a much cheaper price then I've seen for the mk3 supra.
Do our supras use the same clips? If not, couldnt I just purchase the mk3 clips and get those injectors? or are there different connections on top of the injectors making them vehicle specific?
Thanks for the help in advance.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
You need to test to make sure they are low impedance if you're just dropping them into your Mk3.
Low impedance have a resistance of 2.5-3 ohms while high impedance have a resistance around 12 ohms. Or just figure out if Stealth's use low or high imp. injectors.
Im not sure on the plugs..They probably aren't the same.
