Common 1990 Turbo Parts Available at Rock Auto
Supracentral
10
Hey all,
I thought I'd put these up here to help you out. These are parts for my 1990 Turbo.
This gives you an idea of the kind of things you can find on RockAuto's site.
1990 Turbo Supra
  • Idler Pulley - DAYCO Part # 89038
  • Power Steering Belt - DAYCO Part # 4PVK0845
  • Alternator / Water Pump Belt - DAYCO Part # 4PK862
  • Alternator (Reman Nippon - 80 AMP) - ACDELCO Part # 3341881
  • Hood Lift Shock - MONROE Part # 901206
  • Trunk Lift Shock (left side) - SACHS Part # SG229017
  • Trunk Lift Shock (right side) - SACHS Part # SG229018
  • Brake Pedal Rubber - DORMAN Part # 20723
  • Clutch Pedal Rubber - DORMAN Part # 20723
  • Brake Pads Front (Axxis) - BECK/ARNLEY Part # 0881279D
  • Brake Pads Rear (Axxis) - BECK/ARNLEY Part # 0881288M
  • Brake Rotor Front (Full cast vented) - ACDELCO Part # 18A330
  • Brake Rotor Rear (Full cast vented) - ACDELCO Part # 18A329
  • Upper Radiator Hose - ACDELCO Part # 14207S
  • Lower Radiator Hose - ACDELCO Part # 18060L
  • 1 BAR Radiator Cap - STANT Part # 18227
  • Radiator Fan Clutch - FOUR SEASONS Part # 36922
  • Water Pump (with gasket) - AISIN Part # WPT068
  • Starter (Reman Nippon) - ACDELCO Part # 3361421
  • 02 Sensor (OE Style) - BOSCH Part # 12051
  • Throttle Position Sensor - SMP Part # TH218
  • Timing Belt (Neoprene) - BECK/ARNLEY Part # 0260246
  • Valve Cover Grommet (Need 12) - BECK/ARNLEY Part # 0396316
  • Wiper Left (OEM Style - metal) - TRICO Part # 203
  • Wiper Right (OEM Style - metal) - TRICO Part # 183
  • Wiper Rear (OEM Style - metal) - TRICO Part # 173
They pretty much have everything you need for maintenance and OE replacement. Prices are really good, shipping is fast and customer service rocks.
