coilpack rewire
koreyd
172
fall river mass
during my rewire project i finished unwrapping the harness and i found a butchered mess. i looked in the tsrm and tewd to rewire it. but my wire colors don't match.
My guess is that the tan wires and the ground and are supposed to be wired in series and the other wires are the colored but i have no idea what goes where any help would be great
Scruggs86.5T
298
Slidell, LA
Technically the tan wires get wired in parallel, but what I think you meant is that all of the tan wires get spliced together. This is correct. All of the tan wires (spiced together into one) get connected through the green connector to the black wire you have show in your second picture. I guess if you wanted to do it without the connector that would be fine you just wouldn't have any way of taking off the whole coil pack assembly without disconnecting each individual coil pack.
So with that being said, if you are directly spicing the wires together it goes as follows;
3 tan- black
white- blue/yellow stripe
black- blue/red stripe
green- yellow
Hopefully this helps you out some.
koreyd
172
fall river mass
thanks. so there is supposed to be a connector between the harness and the clips.
that was totally missing here.
off to rewire the packs now
SURUKO
making the supra better..
Jan 8, 2007
610
The tropical island....
hopes this can help you i figure it out during my new coils wiring
B/O is the + one all conectors are attached to it
Scruggs86.5T
298
Slidell, LA
Yep, it's just a square, green, four pin connector almost exactly like what connects to your CPS, even has the clip like the CPS connector that holds it onto the CPS. Good luck with rewiring, hopefully everything goes well for you. Sounds like that harness was pretty hacked up.
koreyd
172
fall river mass
yeah the harness was all hacked up at the coilpacks and a couple of the connector.also looks like there was a little fire that crispy fried some wires. i have replace all the bad stuff and rewiring my 89 turbo harness to clip into the 90 na body
the coilpacks and about 6-9 more wires and i am done. hopefully my beast starts after this
while i am at it i am going to lengthen the coilpack wires to relocate it somewhere not on top of the motor
anyone know where these four wires are suppossed to go
what are the white red wire and the white green wire for off the na 90 harness
anyone got a clue what the blue wire is supposed to go for the na car. supra.nl says c1 clip pin 6 but where does it get connected to the 90 na
or do any of these wires go anyway for an na body
koreyd
172
fall river mass
yeah it was. i didn't know it was. someone had rewrapped the harness without repairing after an engine fire. but its the only turbo harness i have. but i am almost done rewiring it and repairing it. other than the mangled coilpack wires. i had to replace about a foot and half of maybe twelve lines where the wires come up and around the intake side of the mount were all crispy. strrangest thing the car that it came from ran. not very well and had what i thought was rodknock. but looking at the harness. the motor might not be totally junk. seeing as the wires were pretty much all touching. but all my eletronics test good per tsrm.
koreyd
172
fall river mass
what is the order of the connectors to the coilpacks
attachment.php
left to right
green - black - white wired injectors
coilpacks left to right
16 34 25
3 tan-together then to connector then to- black
white- connector - blue/yellow stripe
black- connector - blue/red stripe
green- connector - yellow
just confirming what is here before i go and solder it alll together
going to be using a connector because i am not sure how long i need to leave the wires for relocation of the coil packs.
Scruggs86.5T
298
Slidell, LA
I'm not exactly sure what Suruko has going on with his picture. You wrote on your last post
left to right
16 34 25
This is different then what I have as far as the coil and wire combos go.
I have mine set up as;
Black-Green-White
1/6 3/4 2/5
which means the yellow would go to 3/4
blue/red stripe to 1/6
blue/yellow stripe to 2/5
I have just recently set up mine for the c.o.p ignition, I am pretty sure this is correct for the order. If not then I need to change mine up. I remember making sure I had the right plugs for the right coils though. Maybe someone else can chime in and confirm.
Scruggs86.5T
298
Slidell, LA
For the other wires, first picture is the B1 connector the bottom three wires in the picture are all for the super monitor computer, on the side of the connector you have showing;
brown goes to ground
red/green to the ecu
white/blue to ecu
the other wire is for the theft deterrent computer
I would say just leave that one alone as other systems like the taillights work in conjunction with the theft system.
I am unsure about the other connectors. Can you specify what part of the body or harness they are on.
Scruggs86.5T
298
Slidell, LA
Let me know how it goes when you hook it all back up. I am pretty sure what I told you is correct. I looked at Suruko's picture again and if you were to number the coils from left to right, left being 1/6, then it would go how I told you. I think when he said left to right he was talking about the connector and the order of the wires in the connector.
koreyd
172
fall river mass
well. i have it almost all wired togeter tinned all the wire tips. i'll finish it up tommorrow. hopefully it warm here soon so i can go put the harness back in the car and turn the key. but i'll tkae pictures of what i did tommorrow
