Code 51!!!
mhopemk3
The CT install SPECIALIST
Jul 13, 2005
762
Jacksonville, FL 32277
I swapped the auto tranny with a R154 and after I completed the job I get a code 51.. Didn't have it before and if I clear the codes it will come back as soon as I start the car.. I know what TSRM says. I have a new TPS that I put on before the swap so that should be ok.. I did not change out the ECU so I am wondering if that may be the problem.. I still have the Auto ECU!
Any Ideas??
mcpcola
7M's = Peoples Champ
Jul 4, 2005
428
Greater Gulf Coast
no that is fine and you did jump the Neutral safety switch i take it. I have a auto wireing harness in a manual car running a manual ECU but the auto ecu works in the car also.
