I posted a thread in the General Section but it's gotten only two responses...
My car will NOT run. My supra was turned off for probably about two weeks. Didn't plan on it being this long, but that's just how it ended up. Just finished bolting the shifter and everything back up, went to turn the key... Cranked up a little bit a shook like an old 440. Naturally I let go of the key... Tried to turn it again, I can hear a little wind-up but no crank, wind-up slowly runs down and a huge, a$$ smelling, dark cloud comes out of the exhaust.
I checked my codes and she lit a 51 which reads as follows:
I searched "code 51" and came up with JetJock's writup. Got to the point of removing the TPS, but I stripped the screw. (Not too worried about it... I can just hack it off...) THEN I find out that the code 51 has NOTHING to do with my car not starting. So now I'm about 5 steps behind where I started cause the problem doesn't show itself in my codes.
If ANYONE can give ANY advice, I would be most grateful.
http://www.cygnusx1.net/supra/TechTips/engine_error_codes.aspx said:51 Switch Signal
Diagnosis
* No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check.
Trouble Area
* A/C switch circuit
* A/C switch
* A/C amplifier
* Throttle position sensor circuit
* ECU
