Code 51 ....HELP ....
bpt-supra
ct
Hi , everyone . I decided to buy a rewire kit and installed it today cause i came up with code 52 . car ran good other then it being lil lazy.Well after installing the kit i earse codes and started the car. it now idles under 500 and kinda hesitates wen getting on it ...i took the car for a ride and felt real good on boost but once i come to a stop the car shuts off.checked codes again no more 52 but now i have code 51. :3d_frown: ...... any help would be appreciated .o BTW the car is a 1989 turbo ,everything is bone stock.. THX
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
Well, I suppose you've either disconnected the TPS [strike]or A/C signal line OR you've created a break in one of those two at the ECU[/strike].
Shouldn't be too hard to track down.
EDIT: ^^ME^^ Asleep at the wheel... I'm out for the night. Thanks for clarifying JJ.
ForcedTorque
Join the 92 Owners Group
Jul 11, 2005
6,099
Being that it is SUMMER, be sure your A/C is turned off and the car is in Neutral or park. Then reset the codes, and see if it returns. Chances are that maybe your air was on when you started the car after the repair. The code reset is fast and easy. Save yourself the trouble of tearing through everything else first.
CRE
Oct 24, 2005
3,485
Denver, CO
D'oh, I forgot about the A/C thing... Also make sure you don't move the throttle when you check for codes or you'll see 51 then too.
jetjock
creepy-ass cracka
Jul 11, 2005
9,439
In the interest of accuracy a couple of comments:
1) A break in the AC signal won't cause a code 51. On the contrary, it proves the signal line is intact.
2) There can be no "resetting" of 51 because it never gets stored in diagnostic memory. It's a real time code that will disappear when whatever condition causing it is corrected.
