so my car starting today ive drove it all day yesterday with no problems
so im headed to work this morning and i turn out on the parkway and slam it she runs up through first hits second (auto) and just slams my face in the steering wheel check light comes on and then starts pulling again.
so i get to work check the codes and code 34
which is:
turbo charger pressure
"turbo charger pressure is abnormal under high load driving"
trouble areas
turbo pressure sensor/turbo pressure sensor wiring/turbo/ecu
now the car is stock with a shimmed waste gate at 10psi
the car has a blown power steering pump which happened Monday replacing on Saturday
my ? is do you think its throwing the code because the motor is under more load with the blown pump?
i have a friend who is gonna let me use his sensor on saturday to do some trial and error.
thanks
justin
which is:
trouble areas
thanks
justin
