code 34 turbo pressure signal
san supra
833
san antonio
does this mean a vacuum line is loose or a bad component?
my car now sputters when i get on the boost even a little bit.
san supra
833
san antonio
this problem happened overnight and i checked all the vacuum lines and cant find any out of place.
my car ran great before and boosted fine up to 10psi or fuel cut.
san supra
833
san antonio
i would like to fix this asap because i am currently job hunting and this my DD. Any input or things i should check? thanks
san supra
833
san antonio
thank you for the reply. A supra buddy sent me some good links and i didnt know this could also be caused by hitting fuel cut. I havent dumped my codes in a while so i bet code 34 is from a while back when i hit fuel cut. I will run the car tomorrow and check for new codes and double check my intake piping. The sputter i wrote about really reminds me of a bad fuel pump so i will also check that.
Ponimau=Ponimayu?
jetjock
creepy-ass cracka
9,439
You appear a little confused. Fuel cut will set 34 and your code may well be old but the symptoms you describe indicate a boost leak you now have, something that will also set 34. Or maybe I'm the one confused. Either way best thing to do is what you said: clear the code and drive the car again. If the code returns you need to inspect the intake tract for leaks.
san supra;1498092 said:
Ponimau=Ponimayu?
Yes, although "ponimaesh" would be more correct. It slipped out. What happens when you're married to one. I need to use the word often ;)
