Code 34 (fuel cut)
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
Alright guys, i just got my new knock sensor put in and i was out test driving my car. i went to floor it and it would only boost to +1 or +2 and cut out at higher rpm. the check engine light came on for a bit and then went off. i got home pulled the code and it threw a 34. At first i thought boost leak so i checked but nothing. my car is pretty much stock. i search some threads and i got code 34 as fuel cut. why would my car be doing this with no mods?
shaeff
Kurt is FTMFW x2!!!!
11
Around
boost leak. check your intercoolerpipes and coupler(s).
-shaeff
87supraturbo19
pearl white
Jan 16, 2006
360
Springfield,MO
last time i checked but thats been awhile, one other thing it takes quite awile to spool. i can also hear it releasing the boost as i floor it like the waist gates stuck open,
shaeff
11
Around
if you hear the pressure releasing, you've definately got a boost leak, which will cause the fuel cut code. ;) chances are it's not your wastegate if you threw a code 34...
-shaeff
