Any solution other than throwing a new AFM at it? No it's not a boost leak I swear. The car will hit it at 7PSI and continue boosting to 10PSI like nothing happened, and it doesn't sluff off or anything, it boosts strong.
supraguy31 said:Code 34.... If you have Wastegate Shims, Remove them and that will clear that up.
Code 31... Wipe off your AFM Sensor with a """DRY""" rag and make sure your Housing Screw hasnt been tampered with. If that doesnt sove the Problem, look at the connections and ensure its plugged in all the way and there isnt wires showing. If all fails, change out your AFM Sensor
Robert
supraguy31 said:Could be a sticking wastegate also. Code 34.... Abnormal turbo Pressure, I did this once to my car also and as soon as I shimmed it, Code 34 Popped on.
Im sure you Know this but make sure you reset your ECU to get rid of stored codes. I forgot to do that before also.
supraguy31 said:Thats a Posibility. Wastegates are funny like that sometimes, Either Sticking Shut or not closing correctly. I would check it. Stock turbo boost is only 5-7 psi and 7 is a little on the High Side. All of mine boosted at or around 6 PSI.
jetjock said:^ All that sounds plausible except for one thing: code 31 has nothing to do with IAT. The code for a defective IAT is 24. Code 31 is for a fault in the Ks signal.
