okay my car is hard to start when the motors cold. It will hit and run for a second for the first couple tries. then it will start and rev to about 2500 then die. once its warmed up it runs great except it idles at about 1200 to 1300. can i also by-pass my fuel pressure vsv? i read that somebody had done this with no problems. so heres my question. where do i start from your guys experience? my codes:
51Switch Signal
Diagnosis
No "IDL" signal, "NSW" signal or "A/C" signal to ECU, during diagnosis check.
Trouble Area
A/C switch circuit
A/C switch
A/C amplifier
Throttle position sensor circuit
ECU
31
Air Flow Meter Signal
Diagnosis
(7M-GE) Open circuit in VC signal or short circuit between VS and E2 when idle contacts are closed.
(7M-GTE) Open or short circuit in air flow meter signal.
Trouble Area
Air flow meter circuit
Air flow meter
ECU
51Switch Signal
Diagnosis
Trouble Area
A/C switch circuit
A/C switch
A/C amplifier
ECU
31
Diagnosis
Trouble Area
Air flow meter
ECU
