code 24
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
so my car is idle and running like shit...i pulled up codes 24(Intake Air Temperature Sensor signal) and code 31 (Air Flow Meter signal) (Vacuum Sensor signal)...not to worried about the air flow code..but code 24..where is this "intake air temperature sensor" located? and how do i fix it?
-mark
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,477
Perkasie, PA
^agreed, check connectivity of the AFM and whether its even any good. Try a friends and see if the code goes away.
on a side note: I always thought you should worry about lower numbered codes first, is this the only exception?
mk3concepts
1j on the way!
Apr 2, 2006
268
Bay Area, Une Town
yah you guys are right..i didnt really worry about the afm because i knew where and what it was..i just didnt know what the "intake air temperature sensor" was..thats what got me worried...but i tested 2 electronics and both made the car feels the same..i cleaned the housing in and out and even the electronics and put it back on..and my car works great now =]
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
mk3concepts;1209627 said:
is it really?..well i sprayed brake cleaner on it and wipe all the dirt off and such..i got lucky then
No, if it keeps working for more than 2 weeks, THEN you got lucky.
Actually, then you'd be REALLY lucky, because this is pretty much a sure fire method of killing your AFM electronics.
