code 22 and 31
122578
just takes time
Dec 16, 2005
n.c.
i was wondering if anyone has had these two codes together?
22 - temp sensor
31 - afm
the car runs great driving its just at idle were everything goes wrong.
after starting the car it runs good till the rpms return to normal after the choke lets go. then the af ratio goes rich, the idle is sporadic almost cutting off and codes 22 and 31.
already switched out the afm twice with known good ones. temp sensor reading fine. did a leak test but nothing.
any suggestions?
supraman74
I bought it SUPPED up
Apr 26, 2007
89
Iowa
Did you clear the codes each time you swapped afm's?
Check the wiring harness at each sensor also.
When you say "temp sensor reading fine" does that mean you ohm's tested the water temp sensor?
122578
just takes time
Dec 16, 2005
n.c.
yes i cleared the codes every time.
i didnt check the ohms of the temp sensor. i cant find the info on what signals to check 4. i want to test the afm wires but dont know how.
122578
just takes time
Dec 16, 2005
n.c.
turns out it was a recently replaced thermostat. i took it out and it ran fine. put it in again and problems came back.
thanks 4 your help.
Shima
I'v got Supra powers
May 23, 2007
215
carlisle
maybe knocked some wiring out of place doing the thermostat and knocked it back after hehe?
122578
just takes time
Dec 16, 2005
n.c.
very possible. i checked all my wires when putting the new one back in. everything seems fine.
supra87ken;1030375 said:
hi my supra dont have thermostat and it works very fine
If you want to call "fine" staying in cold start enrichment for a very long time while your coolant take forever to get to ops temp (176 deg F). Not using a thermostat on an EFI car (like the Supra) is a very bad idea.
sogi99
115
Elk Grove, CA
there's a reason why the car has a thermostat in the first place. Otherwise, toyota engineers wouldn't have bothered to put one in there if it doesn't need. just my 2 cents
