code 14 HELP
maitai69691
280
hilo hawaii
ok so i been dealing with this problem for some time. 7mgte fresh rebuild cranks but will not fire no spark. only code is 14 no ign signal.
So far replace Igniter, coil pack, plugs wires, checked CPS and did a continuity check on every wire in the ignition system having to do with this problem looking for a broken wire. still cant find any problems...have done many searchʻs on this problem with no help...any suggestions would be grate...
