Well I'm not sure what dial is for test function but I did find another way. I took aluminum foil and folded small pieces in to thin long rectangles to fit in to the sockets of each pin, shoved them in there and clipped the male and female clips back together (to complete the circuit) and attached the volt meter to the foils with the setting to volts. Only while the engine was turning over, I was getting 0.01v, which tells me enough that signal is flowing while the star wheel and sensor is fine. I couldn't continue to attack the cam sensors with this method because of the weather but I will get back to it hopefully tomorrow. From the cams, I will then attack the signals going to the igniter and double check a fuel injector, then check from igniter to coils to see if it just isn't both of my igniters being faulty.
Dirosa, I have not checked to see if polarity was correct but you did shine light on a potential problem, as someone else extended the harness and the colour theme at the ECU connector would still be factory. I will unplug each sensor and run 12v through each wire to the unplugged ECU to see if the wires are at their correct pins and not vise versa. Thanks again!
miekedmr, I sure hope it is not the case haha. I did borrow another ECU that I use to own, that I've sold with another engine swap that I had tested by another member here to try and help him solve a problem of his own, and that ECU checked up fine. Hopefully this other one I am running isn't what you had described.
Motorider9911, I have never heard of that method or that kind of setting, nor do I know if I have it but I will try the long way and send 12v from the sensor harness connector to the unplugged ECU to see what pin it's going to on the other end.
Somewhere in my gigantic family tree I better have a uncle name bob ffs!
Question - would a Stinger ECU be able to diagnose a problem as if it were a OBD2 or better? Just curious. My brother had brought this up, meanwhile I use to own one but I am interested in grabbing another in the future for upgrades.
