Code 11 troubles are back tonight..
Turbo Habanero
4,229
Tucson,AZ
Im not the best with a multi meter and i just bought a new cps I also have a new engine harness that I'm thinking about just swapping in.
AJ'S 88NA
2,419
Florida
Turbo Habanero;1830922 said:
Okay so im super confused now.. I've now driven the car about 110 miles on 12 degrees timing and the problem has ceased.
I tried having someone sit in the car to watch the check engine light as I played and moved around every wire in the car and nothing happens.
Are you setting the timing with the jumper wire?
AJ'S 88NA
2,419
Florida
Something isn't right then. Should stay in time for one thing. Should run just fine at 10 deg.
Have you checked your timing belt?
Checked to see if the cam gears are on the marks?
Turbo Habanero
4,229
Tucson,AZ
Timing belt is new but i have Titan adjustable cam gears and they do seem a hair off I can't even say that there a half of tooth off because its less then that
