Well, I'm not too well versed in repair techniques for a wiring harness I suppose. Part of me thinks it'd be easier and more reliable (that's more of a given) to just replace the offending wire.
Unfortunately I'll come back to that in a minute.
I discovered today at the worst possible time that the code 11 and the car shutting off randomly... Are unrelated. Just so happens I had that code when something else is wrong. It did it to me this morning on the way to a final exam. Only code I found is a 27, due to missing the sub oxygen sensor. I know there's a perfectly good explanation, but man this is frustrating. It ran flawlessly all last week, no codes (except for the 27), then today boom.
The car was idling a bit low. Like. I'd say about 550-600 rpm. Gonna take a look through the tsrm, but any hints on where I could start seeing as there is no nannying from the ecu to help me? My first thoughts move to distributor or some such.
Back to the code 11 issue though. If it occurs sporadically, would it not be rather hard to find the actual fault in the wire?
