Hey I have not done a clutch on my 87 supra, what will i need to get the job done and do i need a long extention to get to the top bolts on the bell housing. Just wondering.
10/12/14mm sockets/wrenches. Long extensions. And swivel sockets or 3/8 swivel adapter. Loosen the motor mount bolts and let the trans hang with the mount off to get the top bolts.
Take ground off battery for when you un bolt the starter. Starter is usually what is the biggest pain for most people.
Iirc stock flywheel bolts are 17mm too. And torques to 58 ft lbs. Pressure plate bolts are 14ft lbs.
