Clutch vibration like its grinding gears....but the gear isnt even engaged????? wtf?
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
So i noticed if the clutch is getting hot i get a strong vibration in the clutch as i let it out. I sounds and feels like its grinding a gear....but it does it when a gear isn't even engaged???? what the hell is going on here?
If i press in the clutch all the way its okay, but once i hit the point where it would normally grab if it was in fact in a gear it starts grinding? If i let it out all the way it stops the noise.
suggestions?
wiseco7mgt
dirty mechanic
Aug 12, 2007
811
queensland
ive seen this before in a car when they put the clutch plate in back the front but since yours has been in for a while id be guessing its either worn out and your getting metal clutch pad rivets scratching your flywheel or maybe youve lost or are in the process of a broken or dislodged clutch plate spring.Just a guess, when you pulling it out?
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
Dont know. I don't have any place to pull it here at school. The clutch holds fine and doesnt slip at all. The vibration only happens if it heats up.
Example: on a steep hill and need to let the clutch out slowly so you dont stall, depending how long i need to burn up the clutch thats when the vibration will start to take place. It goes away in a few minutes of cooling down.
SPD TRP
Formerly 3rdtimearound
Apr 12, 2005
526
Katy Texas
Are you sure that what you are feeling isn't clutch chatter or shudder?
It will feel like an uneven and un-smooth engagement.
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
aberabee said:
sounds like clutch shudder to me...but its funny that it only happens when its warm...
correct me if im wrong but clutch chatter to me is more choppy engagement accompanied by vibrations, like a shuttering as if you let the clutch out too quick. This is a straight grinding noise accompanied by vibration even if the gear is NOT engaged remember
SPD TRP
Apr 12, 2005
526
Katy Texas
So are you saying if in neutral and you press and release the clutch, you get a straight grinding noise?
If so, I would lean more towards your problem residing with the clutch and/or transmission, with the clutch components being the first place I would start probing.
Wayne
aberabee
51
south carolina
touche,
the grinding wouldnt be a symptom of clutch chatter.
the only other thing i can thing of is that the clutch is not disengaging all the way...
IwantMKIII
WVU MAEngineering
Jun 12, 2007
2,480
Perkasie, PA
aberabee said:
touche,
but the shifter is clearly out of gear?
