I have a 1jz with an all motor supra flywheel and exedy stock spec clutch and PP. It's mated to a w58, but I am running a 7m clutch fork extended to reach an is300 slave cylinder. With the rod out of the slave there is plenty of play on the fork before it hits the PP so I'm pretty sure that's not dragging. It was slipping really bad so I pulled everything out, resurfaced the flywheel and PP and put it back together. It was good for a week or two, but now I'm having a slipping issue again, sometimes it will catch for a few pulls, then next time I get in it's slipping again.
Someone please help, should this setup be working? Could this just be an adjustment somewhere? Mabey I need to lengthen or shorten the pushrod on the slave?
