clutch problem
cheverlot
auto tec
Nov 5, 2006
70
south carolina
I have a 88 turbo the clutch pedal goes to the top before the car moves I have replaced the clutch kit I have also replace the master cylinder and slave cylinder
can anyone help? also has any one used a slave cylinder rod from speed source?
adjust it per the TSRM, sounds like the freeplay is too tight and can be possibly preloading the clutch and can cause it to slip (ask me how I know)
Grimsta
1,081
Santa Rosa, Ca.
NOOOOOOO F1 sucks, thats your problem dude!!! Same damn thing in my wifes G20. DAMNIT F1 Strikes again! Its their pressure plates, i think they pull the same scam as XTD, we should make F1 Racing Clutch scam a sticky too, seriously. If any mods see this can we make a thread of that? Since I sell ACT's I'm goin to put the sprung HD 6 puck in the G. I have a selection of clutches in the Drifters Corner.
Grimsta
1,081
Santa Rosa, Ca.
Nah, its nothing else but the F1 clutch. I know you dont want to accept that considering the money you spent, the time it took to install, but that is what it is. I'm telling you, I had the saaaaamme thing with my wifes G. And I know others have had the same problems with F1. They're assholes too, trying to avoid direct confrontation and tip toeing around the issue when you bring it up to them
AF1JZ
Almost civilian status...
Jun 26, 2006
3,109
Fredericksburg, VA
F1 and XTD suck extremely bad!!! I have the XTD "stage3" clutch kit in mine. The chatter is unbearable and makes for a shitty drive when you are starting out in first. It absolutely hates multiple launches. I plan on upgrading to Driftmotions upgraded PP and stock disk when I do my single turbo swap.
Grimsta
1,081
Santa Rosa, Ca.
yeah i had the F1 stage 3. Chatter and when takin of in first it would make like a wheel bearing howl. F%&king retarded
Grimsta
1,081
Santa Rosa, Ca.
My disc was alright despite the chattering to high hell, but the pressure plate was weak as f&^*, get a good strong ACT pressure plate. I have some ;)
