Clutch Problem...?
Feb 1, 2006
154
Columbus, Ohio
Hey everyone. I am having a slight problem… I was out driving yesterday and my Supra ran like a champ. Now today I go to start it and the clutch feels really “weak”, like there was no pressure, but it still started. The clutch just feels like a loose pedal that has no purpose. Did my clutch go out in the middle of the night or what?! I am not sure what to do here…
Any info/help is greatly appreciated.
Thanks,
Adam
t4boost
I gotta have my boost!
Mar 23, 2007
106
Arizona
have you checked you resivor? Check the fluid level, If clutch feels funny like there is no pressure in the system you probabally have leak somewhere.
t4boost
Mar 23, 2007
106
Arizona
Its next to the brake master cylnder. it looks like the mini me of the brake master. Brake fluid has a yellow tint to it, on old fluid its even darker. It on the firewall in the left corner.
t4boost
Mar 23, 2007
106
Arizona
Left corner...driver side... same difference, I would check at the slave cylnder itself.
Feb 1, 2006
154
Columbus, Ohio
well I located the leak inside of the car right by the clutch pedal. So I pulled out the master cylinder and it looks pretty bad/old/ruined. So I am getting that replaced. Should I just go ahead and replace the soft line and slave cylinder while I'm at it? It would seem to make sense.
