Clutch Lines
JASONA70
nomnomnom
Oct 27, 2006
743
socal
im doing a 1jz swap as well as a r154 trans swap from an N/a automatic. i need some info about the clutch lines. my mechanic said he needed the hard or soft lines. i dont know which ones he needs. i think he said the hard clutch lines. i need some more info please.
Troyota
I Love What You Do For Me
Jul 28, 2005
243
Roswell NM
He'll need both. The hardlines come from the master cylinder down to the bottom of the firewall. The soft line connects the hardlines to the slave cylinder.
JASONA70
nomnomnom
Oct 27, 2006
743
socal
where can i get clutch lines? what is the specific's of these lines? how much do they go for, for each line. ive seen some Stainless Hydraulic Line TRD Teflon. i have no clue when it comes to transmissions.
Troyota
Jul 28, 2005
243
Roswell NM
You can either source them through a junkyard (I think this is the place I'm gonna get mine from). You can order them from a Toyota dealer (probably pretty expensive). You could even just buy a length (not sure how much you'd need) of brake line and and have it bent (or bend it) to work.
I'd stick with option 1 or 2 unless you know what you are doing...it doesn't sound like the shop that is doing the work feels comfortable w/ option 3 or they would have already put it to you.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
I have a new braided stainless teflon jacketed clutch line ($40) and I can supply the hardline too ($12?). I also have the master and slave cylinders brand new for $55 and $45 ea, Aisin brand, same exactly as from the dealer. It's a good idea not to go used for the master and slave as most of the old ones leak.
Troyota
Jul 28, 2005
243
Roswell NM
^ See, there is a good source. :D
On a side note: I wasn't condoning the use of used master/slave cylinders...just the hardlines. :D
JASONA70
nomnomnom
Oct 27, 2006
743
socal
i need the whole set up with the clutch lines.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
That's what I figured you meant. :icon_wink
The slaves are usually good for a while but most of the cars we see now with the origional master are leaking, and it leaks inside the car.
