The pivot for the fork I broke off the 2 bolts that hold it on just by the force of the clutch. I used a pick to un screw the remaining bolt in the holes, then replaced the bolts with strong allen head metric fasteners. (was a bitch i had to use a bent allen key to install)
I just need to know if my fork is being moved too far or not. If the movement is normal then i will downgrade to OEM PP & disk so i don't kill yet another new bottom end.
