Clutch for Tremec T56 Magnum + JZ
Archon
67
Russia
www.200mph.ru
Hello,
Who have run T56 Magnum with 1JZ-GTE or 2JZ-GTE engine, please, write this thread what clutch you use and what about pedal pressure and smooth engagement and what horse power or torque your engine.
It will be very useful.
Thank you
nathaninwa
377
Aberdeen, WA
Depending on the adapter ran, you can run any supra clutch. Just call the maker and have the disc splined for the GM tranny. The clutch that 525gte is running was bought for my car, then I changed directions and need the triple in the link. He has a Stage 4 or 5 from Competition clutch. The maker can also supply you with a push style pressure plate so you can run the internal gm slave.
Archon
67
Russia
www.200mph.ru
Thank you, nathaninwa. In Russia we have no dealers whom you can call and they can sell you custom (JZ clutch with GT-R clutch discs) clutch. We can only order from Japan or USA dealers or somewhere else. So, as I understand, you use usual triple clutch for JZ with usual clutch disc for GT-R? What GT-R? So shaft and splines on T56 Magnum is completely same with Nissan Skyline GT-R gearbox?
Thank you.
Anybody run 7.25" clutch?
