Hi guys,
I am in the process of finishing my 1JZ swap, I have the engine in and running but my cluster is acting really weird and I'm having a few problems with it.
1) When I first started the car the tach worked but it was incorrect (showing idle at 200 when around 900 and showing 500 when revved to around 3000), now it doesn't work at all, I have run a wire straight from the ignitor to the M1 plug but it still doesn't work.
2) None of the gauges ever worked, except for the tach but that quit too. Even the clock doesn't work
The cluster was functional when I pulled it out of my parts car (1990, and mine is an 87 both turbo), and the door open and the ABS lights work but none of the other ones work.
I pulled and reinstalled the dash, is it possible that I missed a ground? I don't think I did but I was reading through the TEWD and it says the ground for the clock/cluster is "R/B no. 4 set bolt" where is that?
I am having the 1JZ break-up issue and I can't pull the codes to figure it out.
What could be the problem here?
