Clock Issues
rs4rush
701
Kirkland, Wa
So I am unsure if their is a button to push to turn it on or if its somthing else but I am unsure how to turn my clock on. I heard it could be a fuse but everything else works like the cigarette lighter etc..... Any ideas?
gelboy1015
Vroom Vroom!
Jan 1, 2007
234
Houston, TX
i had the same problem, my clock wouldnt work, so what i did is check the fuse (i think it was the guage fuse, not sure), it was busted, so i changed it and the clock worked fine
advice: check the fuse
CRE
7M-GE + MAFT Pro + T = :D
Oct 24, 2005
3,485
Denver, CO
gelboy1015 said:
advice: check the fuseS
That's better. ;)
I'm pretty sure that with the guage fuse blown the clock should still light up, same goes for the dimmer. It just won't dim when the headlights are turned on.
The taillight and the dome fuses are what I would look at first.
