Clearance issue on pads to rotor.
Koenigturbo
1,336
Oxnard CA
I have a 03 Solara, I wondering about the brake pad to rotor clearance. Every time I step on the brake I can hear a slight creaking sound from the brakes. It sounds like the pads have to much clearance between the rotor and pads. I can especially hear it at the rear brakes. Anyone have the specs? I'm not sure, but I thought the clearance is about 50 to 60 thousands, does this sound right? Are there different size shims to use?
Thanks!
mkiiichip
1,434
WI
The pads should always be touching the rotors.
So to answer your question, 0 clearance.
Have you inspected the brakes?
Are the pads wearing evenly? Whats the thickness?
