Cleaning engine bay
Eamon
98
USA
I am planning on cleaning my engine bay for the first time soon. By the looks of it, it hasn't been cleaned in years. As this is my first time cleaning it, are there any components I should avoid while doing it? Also, what cleaning products would you all recommend?
Oh and before you flame me I did use the search function and found no useful info so please don't...
enjoi.this
Formerly ChrisC
Aug 18, 2008
674
Kelowna, BC
engine degreaser and power washer on a LOW level works well. just have to stay away from rubber lines, electronics or anything that can get damaged by water.
barkz
363
Afghanistan
do a wire tuck while you're at it! i've only tucked one corner and plan on doing it all(when i find the motovation lol)
Jay C
283
Omaha, NE
Don't mean to thread jack but barkz can you explain what wire tucking is? Is it just relocating/rerouting the wires my engine isn’t plumed in yet so this would be a good time for me to do this I have no problem rerouting the wires but I don’t want to cut into the harnesses to remove excess wire. I searched and found one other person who asked a question and got no answers and reread your original thread when you were starting. BTW how did court go?
Inygknok
Tropical Paradise
Sep 22, 2005
488
Puerto Rico
You're right on the money with what a wire tuck is. You literally try to "tuck wires". It's not as easy in our cars as it is in other cars, but you can hide a fair amount of cables. I'm in the middle of doing one but I can't find my camera anywhere. A few things I did.
Made the O2 sensor plug come out of the harness early so it just extends about an inch to plug into the O2 sensor really fast instead of going all around the engine. Removed the entire cruise control system which cleaned up quite a bit. Where the cruise control used to be, I placed the igniter since it's easier to get to there instead of hiding it inside the fender or something. I will probably place the fuel injector resistor next to the coil igniter. There's also a blue box that serves as a ground of sorts that goes attached below the igniter in its stock location; I moved that along with the igniter as well. Since I went with the 2JZ-GE COP mod, I made the cable that hooks up to the coil pack harness come out from behind the head instead of going around as well. I also removed from inside the engine bay all of the plugs that were associated with the cruise control system and are now tucked inside the fender where they come out from, leaving only the brake master cylinder cable there. I have the 12v fuel pump mod as well so I tricked the fuel pump relay how shaeff said to do it and hid that as well.
Can't remember off the top of my head what else I did. The next best thing you can do is run the main harness below the intake manifold instead of over the top.
barkz
363
Afghanistan
^ cruise delete cleans up alot by itself. aftermarket boost gauge too(deletes boost sensor/wire, and vacuum lines running there). thats the one corner of the bay i cleaned up so far. did it all, including install of new boost gauge in about 10-15 mins. with tuck. DAMNIT now i wanna go do some more, but its raining...boo
http://www.nemotorsport.com/boards/showthread.php?t=9765
thats what it looks like.
Inygknok, got any pics of your set up?
Chambers
Now you know
Sep 9, 2007
983
Baltimore County, Maryland
I recommend simple green or marine clean. When I pulled the 7M out of my 87 I used marine clean and it worked wonders. Needed a few towels and two squirt bottles, one for the cleaner, and the one for water.
tried Purple power simple green and degresser on a buddys bay and the only that would touch the dirt was good ol wd 40. Now that shizit shines like a mofo.
Emilian
161
Farmington Hills, MI
I would suggest using Purple Power and good ol' gasoline. Just put a little gasoline on a shop towel and go to town with it. It worked out perfect for me.
