civic turbo HONDATA help.
Nomad707
Im From The Bay
Mar 14, 2007
1,039
Santa Rosa, California
Trying to help my friend fix his civic... it's boosting 7 or 8 in first and second.. and in 3rd 4rd 5th it hits 10 which he has his fuel cut set to 15% duty cycle and the turbo's good for 25 PSI. and wastegate activation 5psi..
T04E turbo A/R 63...
Hondata says to set between 15% and 85% duty cycle.. Any idea's anyone?
figgie
Twin Cities, Minnesot-ah
15% Duty Cycle for fuel cut?
If the fuel pump can handle it (you never mentioned the size of the fuel injectors)
you want to turn that up to 85% DC for fuel cut.
MKIIINA
Destroyer of Turbos
Plano, TX
set the duty cycle higher. anything above 85% and the injector can become static (open almost all the time) which is a bad thing. 15% is fairly low.
does he have a boost controller? has the car been tuned also?
tissimo
Stock is boring :(
Melbourne, FL
I dont think he is explaining it correctly, I assume the Duty cycle he is talking about is the Boost Control Solenoid. Lower it if you can, if not remove it all together and get a different boost controller that will allow you to run lower boost.
