Ok first of all I just installed a used jdm motor in at the begining of the month.
Runs fine but it idles a lil under 2k when motor is warm after I have adjusted it the lowest it will go. When I drive for about an 30 min or more around town it starts to choke and then dies. I have to chill for 10 min or so untill it cools down to start it again. The temp gauge reads normal but when I get out to check the top radiator hose it does not have any pressure? I know the vaccume hoses on top of the thermostat housing are broke. So could that be the problem?:1zhelp:
