I just wanted to make sure that when using an inductive timing light while cranking the engine, if indeed there was spark the light would flash? Or does the motor have to be running? I have tested all of the ignition components following the directions and also swapped them out on a running supra, all but the cps. I did check the air gap and ohm meter deflection and it checked out. The coils spark when tested but it is a weak looking spark. I think it would be enough to ignite the fuel though. I could barely see the spark with my face right next to the plug when testing, so i thought i might not see it from inside while cranking. thats why i ask about the timing light. I have triple checked the timing gear and crank position. There is no way to be 180 out if all the marks are in the right place is there? Sorry for the length just trying to be clear.
