checking my logic
Ok...that's good (if you can call a spun rod good ;) ). I'd still have it checked for roundness like MDC suggested.
FYI...Toyota bearing come in various thickness. You can measure your clearances and get the proper bearing as close to min spec as possible...even if different for each rod.
You are going to replace all of them correct? Might as well have the journals micro polished too.
89mkthree
supies ignore irish luck!
Apr 12, 2005
138
near chi town
i think he is gunna cut all of the journals, so all of the bearings should be the same size. can he machine shop check the rod for roundness?
They should be able to. Unless the journals are really out, a good polish should suffice. The journals have a hardened surface that is not very deep...taking much material off will be counter productive. IMO, it's better to match bearing thickness to each rod.
A good balance wouldn't hurt either ;)
89mkthree
Apr 12, 2005
138
near chi town
ok so i just got my ARP head bolts, and the directions are confusing, or im just really tired. do i torque them to 75 or 85? please help!
The ARP bolt spec for an aluminum head (like a Supra's) is 75 ft/lbs. w/ moly...more is NOT better. I highly recommend chasing the bolt holes to get rid of any burrs/debris for an accurate torque reading when you install the bolts.
