Check out whats coming from my turbo!
sparkplug619
2 Supras, 1 Paycheck =[
Sep 28, 2008
285
San Diego California
I just did an oil and filter change this morning, hit my intake with a little carb cleaner and a new air filter, changed my tranny fluid last night, tightened up my bypass valve because of a boost leak, pulled off my lower intercooler hose and oil over the walls of the intercooler!
figgie
Twin Cities, Minnesot-ah
that is being pulled from the PCV system (the pipe that is connected to the intake covers).
So as long as it is not puddled in the IC. a film of that is quite normal.
sparkplug619
Sep 28, 2008
285
When I pulled it, it didnt really seem like a film though, I dont know how much should be in the IC but as soon as I pulled the pipe, the oil dripped a few times.
When I was changing out my bypass valve a while back I noticed a little oil in there too. not alot at all but there was still some oil. But last night when I tightened up my bosch bpv, it was clean!
figgie
the next question would be how many miles between the times you checked.
Dripped out, still fine. If you wouldhave said a stream came out of your IC pipe. Then start focusing on the turbo to see if it has any play.
sparkplug619
Sep 28, 2008
285
only about 40 mi.
I dont know if this is correct but in my n/a my oil pressure will be a little bit below 40 at idle. I gave my car a fresh oil change a pureone filter and 6 qt of 5w-20 synthetic oil, when at operating temps, it idles at the line before 40, 20 i believe. Is this normal or too low?
S.A. supra
2,405
Buda, Texas
some times oil seals in turbo leak out oil and it pools in the ic and ic pipes. From what you describe. You should be OK. Its normal to have some oil in the ic pipes if you run it hard.
sparkplug619
Sep 28, 2008
285
Thanks for the info!
Where is my oil pressure gauge supposed to sit though? I mean with a fresh oil change shouldnt it be at the 40?
88_7mge
N/A Lover
Dec 1, 2008
32
Hemet, CA
dude, 5w-20 oil is WAAAAAY too thin for that engine. toyota recommended 5w-30 when the motor was fresh. you should be going thicker. Most guys i know with older boosted engines are running 20w50 oil compensate for the wear on the engine. Im assuming the motor has some miles on it. at least go to a 10w-40 oil for now, see if that brings your oil pressure up. if not, then try 20w50, or look into replacing the oil pump...i've got one with 80K on it out of a 89 turbo motor for sale. lol
sparkplug619
Sep 28, 2008
285
5w20 too thin? crazy, I was scared to go any thicker cuz the oiling problems I am always hearing about! Ill read up and drain this stuff out!
