Chaser harness vs. Soarer harness
Cya
628
Columbia, S.C>
Are there any differences? The guy that I have wiring my car can't seem to complete a chaser harness. So I was just curious as to what the differences between the soarer and chaser harnesses were besides the ecu pinouts. Thanks for the help. ED.
aphxero
787
Seattle, WA
are you talking x90 vs jzz30TT? They are the same ecu pinout.
The body plugs/functions are different. I dunna man if your guy can't figure something out like this maybe he shouldn't be doing it?
tavarish
Jersey
the ECUs are the same and interchangeable, but the harnesses are not.
I'm running a chaser ecu in my sc300.
Th problem with a chaser harness is that 2 of the 4 ECU plugs are inegrated into the body harness, which isn't included. You pretty much can't wire it unless it's not going into a chaser.
You can use the ECU, harness is pretty much useless. Time to get a soarer harness or go custom.
Cya
628
Columbia, S.C>
My main problem was the two ecu plugs being missing, it looks as though they were non engine related functions such as the fuel pump and such.
Here is a link to a pinout I found.
http://www.trackdaymedia.com/~manny/Tech & Diag/1JZGTE__JZZ30__pinouts.pdf
The 16 and 28 pins are what im refering to.
Which plugs whould I need to use from each pins?
