Are there any differences? The guy that I have wiring my car can't seem to complete a chaser harness. So I was just curious as to what the differences between the soarer and chaser harnesses were besides the ecu pinouts. Thanks for the help. ED.
tavarish;1191634 said:the ECUs are the same and interchangeable, but the harnesses are not.
I'm running a chaser ecu in my sc300.
Th problem with a chaser harness is that 2 of the 4 ECU plugs are inegrated into the body harness, which isn't included. You pretty much can't wire it unless it's not going into a chaser.
You can use the ECU, harness is pretty much useless. Time to get a soarer harness or go custom.
