changing w58 trany oil
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
make sure the car is level, take out the side filler plug, take out your shifter assembly from inside, and pour your oil in there until it starts to dribble out the side fill hole, then put ti all back together
bishop40k
148
Lafayete, IN
The way I normally change tranny oil is: remove the fill plug (the one on the side), place drain pan under the drain plug, remove drain plug. While the tranny is draining, remove the shifter, when the tranny stops draining (can take quite awhile if the oil is cold), put the drain plug back in. Pour a quart in, let it settle, then another 1/2 quart, stick finger in the fill plug, if you can feel the oil level then you're close, when it starts coming out of the fill hole then it's to the top.
Just remember to use the right weight oil, I have found living in Indiana, 80w90 is too thick and doesn't work too well when it's cold.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
use a funnel and be careful if you put it in through the shifter hole, or i picked up something at the hardware store that looks like a big metal syringe with about 8" of clear plastic tubing that's used to transfer gear oil.
