americanjebus said:
this was covered already in the faq but i got the most out by disconnecting the oil lines that run to the radiator, the left/driver side of radiator has the hose where the oil comes from i put that in a container turn the car on for about 10 seconds or untill the fluid stops coming out, (only about 2-3 quarts will come out then it will stop coming out), let it pour out, measure how much came out and pour the same amount of new fluid down the dipstick, do this 2-3 times and you'll get almost all of the fluid out instead of just diluting it.
Yeah see, I thought I would be able to get more out from the drain plug if I kept the motor running for a few seconds, but all I could still manage was some 2 quarts. I guess the tranny needs new fluid to push out the old fluid.
I did calculations on this actually. The tranny holds about 7.6 quarts, and draining from the drain plug removes about 2 quarts of fluid. If we assume uniform mixture of the new fluid with the old fluid before draining:
1st drain: 73.68% old fluid or about 5.6 quarts
2nd drain: 54.29% old fluid or about 4.12 quarts
3rd drain: 39.94% old fluid or about 3.03 quarts
4th drain: 29.38% old fluid or about 2.23 quarts
5th drain: 21.61% old fluid or about 1.64 quarts
6th drain: 15.51% old fluid or about 1.18 quarts
7th drain: 11.43% old fluid or about 0.869 quarts
8th drain: 8.42% old fluid or about 0.64 quarts
9th drain: 6.2% old fluid or about 0.472 quarts
10th drain: 4.5% old fluid or about 0.348 quarts
11th drain: 3.37% old fluid or about 0.256 quarts
12th drain: 2.48% old fluid or about 0.188 quarts
If we only consider the old fluid at the start of this process, after the 12th drain only about 0.188 quarts of it remain inside the tranny. The only thing is, we need to drive the car around long enough to allow the transmission to mix the new fluid with the old fluid uniformly so when we do drain the next time, the mixture of the fluid that is drained is also uniform.
So by looking at the numbers, if you want new/fresh fluid in the transmission, draining once a month would be sufficient to replace 97.52% of it within a year.
