Causes of Fuel Cut beside boost leaks?
twinturbozs
131
san francisco
Im getting FC when i romp on the throttle in the early rpms (3-4k). I tested my IC pipes and i have a very small leak inside the turbo itself. But the system can still hold pressure for at least 5 minutes losing about 2psi per minute. Doesnt seem like enough cause FC.
Are there any other reasons for FC besides a boost leak?
SP61GT
Lexus AFM/550's
MKIV fuel pump
Im starting wonder if i actually have 550's injectors installed. Since i bought them from another member years ago.
MDCmotorsports
Indy 500
www.MDCmotorsports.com
Large turbos flow more air at less psi.
So if your ct was making 14psi with no fuel cut, your SP61 is now at around 10-11psi with fuel cut...
FIX THE LEAK.
(The leak may be causing the wastegate to stay shut)
twinturbozs
131
san francisco
The leak is coming from within the turbo. Might be from the brass nipple to the wastegate line. i cant be sure, but its not coming from the pipes since i was able to spray them with soapy water without bubbles.
LordLo
242
OR
Mine does the same thing, on my ct26 it was hitting 15 psi fuel cut. Now with my t4 it hits fuel cut around 10 psi. I'm going maf as a fix, since maftpro is too expensive.
