catch can question
supraguy@aol
Well-Known Member
Dec 30, 2005
4,283
76
Atlanta
Yes, Mine is similar, just round.
However, the best design, is to have a wall, inside the can, separating the inlet side from the outlet side, so that all air is forced down to the bottom, and then up to the outlet through a wire mesh, to allow the fumes to cool.
The mesh captures the condensated oil. Ebay cans don't do this. What I did, was add a tube inside the can, to force the inlet air to go to the bottom, and added some stainless steel wool.
91Supra313
1,062
Clarksville TN
Wow! I have been looking for this thread since I posted it. I had no idea it was moved. I guess it doesn't belong in the oil section.
Ok so there has to be an outlet on the can? Where the heck to I vent it to? My friend has both lines for his GReddy can going to the valve covers. One for each cover. I always thought that was how it was supposed to be installed. If anyone has any pics of their install please hook me up so I know how to put mine together. After I find one I want of course...lol. I was looking at one from NRG Innovations.
supra90turbo
shaeff is FTMFW!
MA, 01440
^ Unless there is also a vent hole (ideally going to a vacuum source, i.e. turbo inlet hose) in the canister, his is setup extremely wrong and he should fix that before it blows a seal out (or worse) due to crankcase pressure.
86.5ny
OC, NY
I'm using driftmotions catch can. http://store.driftmotion.com/static/i-oilcatchcan.php
I'd say comparable to greddy, pretty good quality. I welded the inlets and outlets to the can, it had no leaks before the welds and no leaks after. It definately gets the job done for me. I am running a N/A and dont know how this effects your judgement. Take a peek tho.
Also, having no vent back into the system is bad as poodles said. I T'd the outlets from valve covers and used outlet on can as vent.
