catalytic converter sizing for 1jzgte
#04
526
Cambridge
just putting some final thoughts into my 1jzgte exhaust system for the MK3..
it will have; 550cc injectors, apexi intake/filter kit, ebay Y-pipe/3" DP, and likely run stock-ish boost for the first season or two until I commit funds to a turbo upgrade...
the rest of the exhaust will likely consist of; magnaflow 2.5" X2 (in/out) muffler in place of a resonator, running to 2.5" pipes around the diff and ending up at pair of Apexi N1 dual 'mufflers' (more like a straight through resonator) (salvaged off a 240sx - stainless mufflers - less stainless piping - good job apexi)
I will likely use only stainless pipe, resonator, cat, to help keep it clean and ever lasting...
what size of Catalytic converter should I be looking at?
3", 3.5"? will the 3.5" be too large to reach operating temps?
I am running a 1987 chassis which means no emissions test in my province, but must pass visual for retain factory components - meaning has cat/muffler/resonator (resonator not so important)
in the longer term, I would like to see this car with around 400whp after turbo upgrades etc, and would like to plan around end goals, rather than intermediate goals..
^using mufflers only - borrowed picture
^for reference - S14/240sx
images
^for reference
te72
Classifieds Moderator
6,622
9
WHYoming
Do you care if it actually acts as a catalyst? If not, simply weld in a pipe that runs through a stock cat's shell. If you do, I would suggest running a cat that matches the size of the exhaust piping for simplicity's sake. :)
Ya from turbos back should be 3in if on stock twins. Can get a 3in high flow and then run what ever cat back you want.
#04
526
Cambridge
ticket price for non-conformity to environmental regulations is somewhere in the $500CAD department..
and may cost; plates, tow, re-inspection...
so using an actual new cat would be best for me... vs ...a ruined weekend
fair enough, so 3" high flow it is then,
5
So long as it's not a bottleneck in the piping, it will be fine. I partial to the spun metalcore cats from magnaflow (raptor racing makes a bolt in version)
Turbo Habanero
4,229
Tucson,AZ
Smart man
