Josh913 said:
			I was saying that it would try to start but never started.
1. How do you check for spark?
2. How hard is it to check/adjust timing?
Josh
1) Checking for spark:
Pull one spark plug wire off. Preferrably number 5 or 6 because those cables are longer. Then hold it near a metal ground (like one of the strut caps?) and have someone try to start the car. Be very cerafull!!!! Keep your fingers not anywhere near the metal part of the spark plug wire! You can see now wheter it fires or not.
2) Ajust timing.
First get a timing light. After that set the engine to TDC by hand. (Using a wrench or something.)
Now put two (white) marks. One on the Pulley and one on the timing belt cover, between 10-12 degrees (see TSRM for details).
Put the timing light on the #1 spark plug wire and start the car. You can point the light at the pulley now and see whether the marks you made are aligned or not.
If not, then set the timing by
0) stop the car
1) Going into diagnostics mode.
2) Loosen the CPS bolt.
3) start the car
4) move the CPS up or down and at thesame time use the timing light to check the timing.
5) If the marks are aligned correctly then shut off the engine and fasten the CPS bolt.
See the TSRM for going in to diag mode and details on your specs for the timing as well as a description how to set the timing if you don't understand mine
I included a picture to show the CPS position.
