car wont go past 2k rpm
Supraflymk3
Supraman
Dec 17, 2005
272
Neenah, Wisconsin, United States
sounds like your tps is out of adjustment or on the wrong way. this happened to me when i put a new engine in my first supra turbo. does it like basically stop doing anything until you shift into the next gear and it does it like that in every gear?
ben1984j
159
Ft. Collins, CO
I also think it sounds exactly like a TPS problem. If the ECU thinks the throttle is closed, but still sees increasing RPM and airflow, then it will stop injecting fuel at a certain point...TSRM says ~1800 rpm for a GE, so 2k seems about right...
jetjock
creepy-ass cracka
9,439
If the engine rhythmically cuts off and comes back on at a lower rpm the problem is caused, as stated, by failure of the IDL contact to open. This is confirmed by the *lack* of a code 51 and the presence of code 41 when the throttle is opened. This is because 41 gets set anytime VTA exceeds 1.5 volts with IDL closed.
SRZMK3
what was happeneing was i had exposed wire on the top 2 contacts of my tps connector, they shorted together and that caused what is happening... i rewired them without a connector seperating each with electric tape and plugging in each seperatley and that fixed my issue.
