Car starts, won't stay on at idle, and runs like shit after rebuild.
iDriftYou
SoCal/805
I finally figured out my starter problem and now the car cranks, has fuel and spark, fire starts and doesn't idle at all. Dies the second you let off the throttle. I even readjusted the timing, took the entire cps, etc. I'm lost, also my gauge cluster doesn't want to work either so that's also another problem, the gauge fuse is fine. I took a video of how it starts and sounds:
http://www.youtube.com/watch?v=dkJKYcMke6I&feature=player_profilepage
Thanks for all the input!
iDriftYou
SoCal/805
So we took the timing cover off and the exhaust cam gear wobbles when the car is running. Its not a lot of wobble, just enough to notice. We checked for intake leaks, moved around the cps and even changed the idle air control valve, I'm completely lost.
8,900
Either the gear is not on the cam, or the cam is bent. If the cam was bent, you would probably notice some other things.
iDriftYou
SoCal/805
The cam gear is on there perfect, how can I tell if I have a bent cam? Also, I can't check for codes because the cluster I bought from the junk yard doesn't work for shit. I need to pick a new one up :: angry ::
